Well today my uncle came to me with this.Saying it only needs a tack. This being the barrel of a shot gun I'm not too sure on this one. Or is it even repairable ?Will Supports Autism Awareness My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:I'd take it to a proper gunsmith, not sure what damage a simple tack would do and its right on the barrel too, You need to think as well as any arc damage caused by the earth.Might be a brazing repair, but only a gunsmith would know best without damaging or distorting the barrel
Reply:Should be repairable with silver solder. They solder the ribs on shotgun barrels. The biggest concern would be not to get too much heat in the barrel. It's definitely a job for someone who knows what they are doing though.You might check with Numrich Gunparts Corp. and see if they don't simply have a used replacement barrel cheap.http://www.gunpartscorp.com/Last edited by DSW; 01-08-2013 at 03:17 PM..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Snap Doug
Reply:First, I would try to replace the barrel, if the barrel is still available or isnt too expensivetackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:I'd Tig weld it up. Then tell your uncle to aim a little higher from now on. Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I would wrap wet towels around the barrel on both sides of it and run a bead across it with mig. I doubt there would be any distorsion.
Reply:Originally Posted by BobI would wrap wet towels around the barrel on both sides of it and run a bead across it with mig. I doubt there would be any distorsion.
Reply:I repair shot guns all the time, depending on where the repair is you can straighten barrels easy, we do it all the time at the gun club I belong to.......As far as the repair if he isn't concerned with getting it BLUED again I have had good results with 308Lstainless.....Just tig it PS don't mig it you will just make a mess........ Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Run water through the barrel to control heat and tig weldMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Keep in mind if you weld that crack, that the connection of the lug to the barrel is probably silver soldered or brazed and will let go if it gets too hot.I also think a gunsmith would be a good idea especially if it is a valuable gun."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Looks like a Mossberg 500/Maverick 88 bbl. if so, replacements are cheap and available should it not be fixableHobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:There's a gunsmith next door to my buddy's shop I'm gonna take it to them. My uncle may need to stop being cheap and come up off some dough.Will Supports Autism Awareness My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:I say replace the barrel and don't mess with it. There are some intense pressures that build up in a gun barrel when a round is fired. Weaken one spot and your risking a nasty kaboom!
Reply:Listen to norite, dollars to donuts that lug is silver brazed and if you TIG it you run large risk of dropping the whole lug off unless you know exactly what you are doing.Experience is something you get right after you need it
Reply:Barrels should not be welded. Silver soldered at most. (Many shotguns, especially doubles, are simply lead soldered due to the risk of warpage.) Originally Posted by FireForge1I say replace the barrel and don't mess with it.
Reply:Originally Posted by CEPI'd Tig weld it up. Then tell your uncle to aim a little higher from now on.
Reply:Originally Posted by KelvinBarrels should not be welded. Silver soldered at most. (Many shotguns, especially doubles, are simply lead soldered due to the risk of warpage.)+1Or take it to a gunsmith.
Reply:On second glance (my monitor is real dark and it's hard to see dark parts of pics) I now see the crack appears to be in the lug, not a failed solder joint.HOW THE HECK DID IT CRACK IN THE FIRST PLACE?Being that the repair would be on the lug, you might be able to get away with welding it, but I sure wouldn't try. You could end up melting the original joint, warp the barrel, or worse.And if you do weld it, I sure wouldn't let anyone hold it in their hands the first time it's fired after the repair!
Reply:Just wondering, wouldn't the type of force needed to break that in the first place already have had a high probability of warping or in some way damaging the barrel. The concern that the barrel is already damaged would be just as important as any damage from a repair.. No???Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:I'm a licensed gunsmith. If that came into my shop I would silver solder it together. Sent from my DROID RAZR using Tapatalk 2Hobart Stick mate LX AC/DCHarris O/A outfit |
