Snap-on MIG220 tig conversion
发表于 2021-8-31 22:57:54 | 显示全部楼层 |阅读模式
I got a decent deal on one so I couldn't refuse... I will eventually upgrade to a miller once I gain some more skill on TIG. It came with a TIG conversion kit with the switch mounted to the torch. I was wondering if there are options for me to install a foot pedal as well. I'm new to TIG'ing although I have done a bit of mild steel one day in welding class (pretty basic class in college). I enjoyed it very much so I had my heart set on a welder for tig. My MIG skills are pretty good which is not all that impressive, I know. I'll be using it mainly for stainless 304 exhaust work so ideas on gas mix/filler rod is welcome. Suggest purging at all for o2 bungs? Any tips or suggestions would be helpful thanks. I know most of you are against the snap-on welders and I respect the reasons behind that, as I said before I'll be getting rid of this unit eventually for a real welder.This is the model, not my exact unit because its just out of the box but to give you an idea on the input/outputs.
Reply:this is the updated version which is what I have the image posted before was of an older less reliable model
Reply:You need to resize the pics in your first post.   Your text is cut off.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Unfortunately I cannot select edit on that post because of that reason. Could a moderator assist in removing the photo out of the first post. Thanks
GMT+8, 2025-12-28 21:45 , Processed in 0.186881 second(s), 18 queries .
