Metal Brake Plans
发表于 2021-8-31 22:57:48 | 显示全部楼层 |阅读模式
Any body got any good metal brake plans that are semi detailed?  I just finished building the gottrikes bender and it was fun so I figured since I had some beefy angle laying around I would see about finding metal brake plans for my home shop.Thanks!
Reply:Did you check out the thread a few days ago under projects?  Here's a link to one that WDB made w/mods that he made to his, and that I made to my little HF 18".http://millerwelds.com/interests/pro...bending-brake/Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
Reply:Awesome that will give a good start for research.  Thanks and if anybody else has any I'd love to see them.
Reply:Take a look at this one.http://www.shopfloortalk.com/forums/...ead.php?t=1297Dave
Reply:Here another onehttp://www.megaone.com/morpheus/brake/bench_brake.htmlYou probably would want to make alot longer than 6".LarryTry not use $10.00 worth of time on $.10 job!!Miller Bobcat
Reply:Originally Posted by LarryMHere another onehttp://www.megaone.com/morpheus/brake/bench_brake.htmlYou probably would want to make alot longer than 6".Larry
GMT+8, 2025-12-28 21:47 , Processed in 0.101917 second(s), 18 queries .
