Is this kind of splatter normal?
发表于 2021-8-31 22:57:42 | 显示全部楼层 |阅读模式
I'm learning to weld using a Hobart Handler 140 with .030 flux core wire. Everything looks good for a beginner, I guess, but I get lots of splatter, is this normal for flux core or am I doing something wrong? Here is the picture of the beads I was running:http://i.imgur.com/RQZKi1Z.jpg
Reply:Flux core is usally a little messy, however I would recommend you turn up your wire speed a little and try to stay more consistent with your weaving motion. Have fun!
Reply:Start burning lines first, and reduce your stick out a bit. FCAW is a bit messy. Clean metal helps reduce splatter.
Reply:Need to change your settings. Looks cold, are you getting a "pop pop pop" vibration?
Reply:BTW, it's Spatter not Splatter.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Check your polarity6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by Drf255BTW, it's Spatter not Splatter.
Reply:Originally Posted by ExpatWelderCheck your polarity
Reply:Spray the area with aerosol Nozzle Clean first and those things mostly brush-off...
GMT+8, 2025-12-28 21:24 , Processed in 0.096772 second(s), 18 queries .
