pipe welders what do you think
发表于 2021-8-31 22:57:40 | 显示全部楼层 |阅读模式
Reply:No pipe welder here, but I think it looks very nice! Was that run up hill of down hill?Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Uphill. Thanks
Reply:It would pass on the job, depending what code, if i were you id  grind your stop starts back a bit more to get rid of the little divits in the start i see, 95% as good as the best ive seem, well done.Sent from my LG-P716 using Tapatalk
Reply:Member here pipe fitter told me on another site. When getting ready to stop, punch the rod through the pipe. This leaves a little hole, and makes a much better tie in when you start the next rod. Now if I could only remember to do that every time.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPMember here pipe fitter told me on another site. When getting ready to stop, punch the rod through the pipe. This leaves a little hole, and makes a much better tie in when you start the next rod. Now if I could only remember to do that every time.
GMT+8, 2025-12-28 21:24 , Processed in 0.187734 second(s), 18 queries .
