Welded Chain Project
发表于 2021-8-31 22:57:38 | 显示全部楼层 |阅读模式
One night while half asleep/awake i knocked the lamp off the bedside table. It broke on impact with the floor. I made my own replacement that is not likely to break, if it does, I will just weld it back together. The first one was not a good candidate for welding. The base was formed around a piece of pipe, then I wrapped the rest around a 2x2 and welded. All this with my MM140 and fluxcore wire. The base wasn't big enough to be stable after welding so I added the 1/4" rod to make a wider more stable base. I reused the working parts of the first lamp to wire this up. I threaded the cord thru every other link and then painted it.This should be a much safer welded chain project than something like motorcycle handlebars. Attached Images
Reply:Nice job and an interesting project.  Thanks for sharingGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Neat ! good idea. There was a post I saw of a chain single wine bottle holder. Pretty slick. Actually I was thinking of using chain to make a rattle snake garden art. Have you done any other chain projects ???
Reply:No, this was a first for using chain. I was thinking of using some to make a small table maybe. Just use heavier chain for the legs/feet and frame. I'm open for things to make with this stuff though. Shows a possibility for what 120V MIGs can do, even if it can't make trailers or hitches, and more than just sheet metal.I have a piece of roller chain 3' or so long that I was thinking of something to use it for, but it looks to be stainless, and I don't want to buy a roll of stainless wire and gas just to weld this into something. But maybe just a few SS rods might do the trick for this.Last edited by Bistineau; 03-05-2012 at 08:55 PM.
Reply:STAINLESS???  Now you have a reason to buy a TIG MACHINE!!! Actually, if you get  a 180SD or 200 syncro by MILLER you would have stick too  !!!!
Reply:yes get the tig machine!
Reply:Not a bad idea. Make a couple more for the pirates to scoop up ($) at a bike swap meet & greet. Maybe 2 more vert arms to hold a beer or 2.
Reply:Originally Posted by BD1STAINLESS???  Now you have a reason to buy a TIG MACHINE!!! Actually, if you get  a 180SD or 200 syncro by MILLER you would have stick too  !!!!
Reply:Originally Posted by BistineauWith the Bobcat, the stick rod welding is already covered. If I need the TIG set up, I just need to get the torch and regulator and stuff. I don't see a big need to weld SS anytime soon, so can't justify a dedicated TIG rig for now. I can still do some AL. work with the spoolgun on the MM140..
Reply:Originally Posted by BD1Oh, so you have a BOBCAT ?  AWESOME ! Yea, like you said, then all you need is the tig set up with lug that goes in the stinger. With the tig set up if chain breaks in bedroom, just drag the cables in there  !!!!!  Actually, that's what I should do to jump start  MA MA !!!!!
Reply:NICE SETUP  !!!!  I remember seeing your BOBCAT set up on another post. Neat. I just finished a running gear for my TRAILBLAZER to  keep in garage . I got a cheap 25.00 partial boat trailer frame ,axle , wheels, and springs that I gonna modify so I can drop the trailblazer and running gear into it road use or field farm repair. MILLER BLUE
Reply:Cool build!  I have made a couple things with chain myself, highway pegs for the bike, shifters for buddies ect.
Reply:Anybody else made a chain lamp or anything like this lately? Just wondering if this thread inspired someone to make something similar.
Reply:Cool build! That is one of the most unique creation that I have ever seen here. How did you manage to do that! Just amazing.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Originally Posted by surfsideCool build! That is one of the most unique creation that I have ever seen here. How did you manage to do that! Just amazing.
GMT+8, 2025-12-28 23:32 , Processed in 0.074193 second(s), 18 queries .
