Went to my lws and asked for 6010 rod. Guy at the counter asked if i wanted 5p or 5p+. Whats the difference?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:5P+ doesn't fingernail as bad, it's a better rod.
Reply:I always thought the red dug a little deeper than the grey.
Reply:go with 5p+ . Unless you are welding on steel that you cant clean in that case go with the red rod. 6010 (red rod) can weld threw cow sh&%. alot of farmers swear by it. On the job sites you will be running your root with 5p+
Reply:Damn, i got the wrong rod. Im trying to use it for my root practice. Can i still get a good feel for how the 5p+ runs by using the 5p? Or do they feel different?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Burn em up, they are both Lincoln cellulose / fast freeze rods made for DC+. I have used both, but haven't seen the + in a while. I don't recall any great difference at my skill level.For $14 or so how can you go wrong?edit: Assumed you got a 5lb box.Last edited by jtcnj; 01-12-2013 at 10:32 AM.Lincoln AC/DC 225/125 and WP17. 75A AC is for pipe thawing!HH 140 - new addtion 9/2012.I didn't agree, but hoped for Hope and Change.I got change for myself and my family: for the worse.This is the reality of: Barackalypse Now. Again.
Reply:you can still run your root with 5p . Thats what every one else did until they made the 5p+
Reply:Originally Posted by TimmyTIG5P+ doesn't fingernail as bad, it's a better rod.
Reply:Regular 5p sucks, it sticks, snuffs out and fingernails, get the 5p+ and be a happy weldor. I personally like Hobart Pipemaster Pro 60 which is there 5p+ equivalent, and I think it runs a little nicer.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by Mikel_24When you say "fingernail" you are talking about freezing so fast that it creates ripples with every slight movement of the rod?The only 6010 I have access to is BOHLER FOX CELL which I have no idea if claisffies itself as 5p or 5p+... but it does create ripples everytime you blink!Mikel
Reply:Originally Posted by TozziWeldingRegular 5p sucks, it sticks, snuffs out and fingernails, get the 5p+ and be a happy weldor. I personally like Hobart Pipemaster Pro 60 which is there 5p+ equivalent, and I think it runs a little nicer. |
