i have an abrasive chop saw, can i put a "cold cut blade" on it? does anyone know anything about doing this???nothing fancy, just a few hot glue guns for metalwww.sicfabrications.com
Reply:Put cold cut saw in the search box, I just pulled up 5 pages of it.But to answer your question, there's a problem with the RPM's...the search will get you a ton of info.Anything worth doing is worth doing RIGHT
Reply:I know the hard whay this will not work. Jancy makes a saw that will work with the cold cut blade. If the RPM is wrong, the teeth could shatter like glass, and maybe someone might get hurt. http://www.jancy.com/index.cfm?fusea...roductServices
Reply:There is also this blade:http://www.bulletindustries.com/cata...roducts_id/784 |
