查看: 13|回复: 0
Plastic welding
发表于 2021-8-31 22:57:15 | 显示全部楼层 |阅读模式
I have a name brand hot air SII plastic welder with various tips. It is similar to Harbour freights cheap copy. I have never had luck making a decent weld, mainly in HDPE, which should be one of the easiest to do. I have double filtered air. I haven't tried nitrogen which has been suggested. Any one have links to online training or videos on the process?  I have 20 kayaks and 15 paddle boats to repair plus many commercial playground parts. Most are HDPE, there may be some LDPE, but I don't think so.
Reply:I was told that old LDPE/HDPE does not like be repaired.   You need heat, pressure and filler to get a watertight weld.  I have not had much luck either.  Even when I get the hdpe completely clear.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I repaired the HDPE bumper on a friends Porsche. Got it painted up and it looked like new.  I used the soldering iron type and first tacked the pieces even with each other. Then I melted some fine stainless steel mesh embedding it into the plastic. I used the filler rod through the melting shoe to cap. The mesh is the key. It won't break there again. I even re made one of the tabs where the bumper had a screw hole. More mesh there.
Reply:Had some cracks in my wheeler rear fender. Found an old cycle fender and cut 1/8" strips from it and used my old Weller soldering gun. Not pretty but they've held good for 2 yrs.                                                     MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I have had many 500-3000 gallon water tanks for fire trucks welded with HDPE and guns similar to mine. The take the pounding and surges of emergency driving. Unfortunately the last guy that made me one moved away, so I can't get a lesson from him. Pierce Fire Engines makes all their new water tenders (3000-4000 Gal) out of welded HDPE. So I know it's just a lack of skill thing on my part. The brand welder is Sealy which was top of the line at the time. I thought it said SII it as well.Last edited by blackbart; 10-15-2014 at 07:26 PM.
Reply:Did you try using a speed tip, the one that you feed the rod into and it melts the rod and the parent material at the same time?There are a variety of them for different rod sizes and from different manufacturers.They look like this  http://www.all-spec.com/products/091...FTMQ7AodencAqA
GMT+8, 2025-12-29 01:14 , Processed in 0.195966 second(s), 18 queries .
