best "sock" welding hood
发表于 2021-8-31 22:57:14 | 显示全部楼层 |阅读模式
Hello...I will be doing a lot of welding in tight positions so I will have to get a "sock" hood.I think that's what it's called.Any suggestions what brand a really good one or a comfortable one is?thanks guys.
Reply:Originally Posted by Jakedasnakea comfortable one
Reply:Yeah,I've tried on the ones with no headgear inside on.You want something that stays on.If you can find one that has a headgear of some sort, see if you like it ....
Reply:Get a pair of flip up burning goggles the type to be worn with glasses, put a welding lens in and take out the shade five, and just wear it over a ski mask and you'll be good.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:You could try this instead of a leather hood maybe?SERVORE ARC-513 Auto Darkening Welding GOGGLELast edited by MinnesotaDave; 10-18-2014 at 01:48 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:That's Cool Dave! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:I was doing some welding where my helmet was too big to squeeze between some bars and I was having to weld at arms-length when I first saw that....$200 seemed too much for something I wasn't going to use often so,,,, I cheeped-out Bought these two things;http://www.ebay.com/itm/140908707589...589%26_rdc%3D1http://www.ebay.com/itm/381021189794...794%26_rdc%3D1Figuring  my neck & nose would be the most vulnerable the leather took care of that and a wool watchcap for my ears & forehead (if I welded for more than a short time I would do more for that).
Reply:those are neat might have to pick up a set in case i run into something that needs it
Reply:This the smallest of all my welding helmets. It even folds up and you can put it in your pocket.
Reply:Now what could be more comfortable than one of these on a 100-degree day?  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPNow what could be more comfortable than one of these on a 100-degree day?
Reply:Thank you very much guys.You all are the best
GMT+8, 2025-12-28 23:30 , Processed in 0.102423 second(s), 18 queries .
