Help needed!
发表于 2021-8-31 22:57:13 | 显示全部楼层 |阅读模式
I just got a Miller Syncrowave 250 TIG welder I got for free. It came with torch,cables and a tank.First I need to have an outlet installed in my garage. I was thinking a 220v 60 amp. Is that ok?I need a regulator what kind/brand should i get?I have never tig welded before i have mig welded a lot. My plans are to make turbo manifolds, Exhaust systems, Intercoolers, etc. for vehicles after a lot of practice! I watched some youtube videos on welding pipe and saw them back purging the tube. How does that work? Can you use the same bottle of argon that you sue for the welder or do you need a seperate  tank for that. Is there a regulator you can get that can use the same bottle to backpurge and weld at the same time?I'm new to tig welding as you can tell and will have many many more questions along the way!Any help is appreciated!THANKS
Reply:http://www.usaweld.com/Dual-Flowmete...lflowmeter.htmWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thanks
GMT+8, 2025-12-28 23:50 , Processed in 0.071644 second(s), 18 queries .
