Campbell Hausfeld WF2000 torch assembly
发表于 2021-8-31 22:57:12 | 显示全部楼层 |阅读模式
I have a campbell Hausfeld WF2000 i use around the house and had to open the torch handle today because the wire was not feeding as i opened it the wire poped out iwas was able to figure the handle push button but when i put the treaded piece back in i didn't remember how the washers went back there are 2 brass washers 1 fiber washer a lock washer and a nut does anyone no what order these go on thanks
Reply:There ya go http://www.ereplacementparts.com/cam...69_124438.htmlhttp://www.manualslib.com/manual/460...0.html?#manualRead my lips..............P-O-I-N-T AND C-L-I-C-K  geez!"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-29 02:58 , Processed in 0.137862 second(s), 18 queries .
