Argon regulator nipple
发表于 2021-8-31 22:57:11 | 显示全部楼层 |阅读模式
Gun has whats looks to be about a 1/4 in hose that slides over a nipple i have no idea what size nipple to order.   Its an everlast 140st
Reply:from the 140ST manual 'You will need to join the regulator and torch by adapting the 5/16” torch gas hose to the regulator."
Reply:The hose is not threaded and the regulator has threads thats why i need a nipple
Reply:You will need a hose barb. Likely 1/4" npt x 5/16 hose. Available at the LWS or a big box store in the plumbing department.
Reply:I put a 1/4 x 6 hose in the regulator would any brass female to 1/4 inch barb work or is there a specific fitting for tye inert hoses
GMT+8, 2025-12-29 01:22 , Processed in 0.125135 second(s), 18 queries .
