查看: 13|回复: 0
Hydraulic Fluid Tank..
发表于 2021-8-31 22:57:09 | 显示全部楼层 |阅读模式
Good customer of ours dropped off a hydraulic tank that goes on his Gradall...He was having someone come and do this in the field but the last time whoever repaired it..well it suffered failure..The sides split down the middle of the weld so...........Now it's my turn..Had to lay it down on it's side without wrecking any of the connectors or fittings so a couple of 4X6'S were put into play..Pics show the split..It was split on both sides so much grinding was needed before anything else..Next post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:So after grinding all the old weld off it was a straight forward weld repair job..I don't think the original weld was ground before the first repair..Just welded over so it all had to go.Nothing like this kind of fun @ 7 AM...There was some fluid on the floor after it got repaired from a loose cap fitting but there was no explosions or fires or anything like that...1/16" 70S-2..3/32" Red..Machine on "Kill"..Chair and pedal in use..Pics are out of order..3'RD one down is pass # 1...I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Good fix bro! Perfect! I get about 1 or two a month to do and never fun at 7am. And worse with somoene standing next to you the whole time waitng for it  Great job tho I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nice beads ..Looks like a nice easy job... Did you purge the tank at all ??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by DemonSpeeder Did you purge the tank at all ??
Reply:For the life of me I can not understand why hydraulic reservoir tanks are so high priced. Am I missing something? Nice fix. Good thing he didn't have to buy a new one!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:great job as always.......
Reply:I wish I could get my welds to look like that!America's enemies best ally,the Democratic Party!
Reply:Very nice job!  You could pressurize with about 3 psi to check for leaks....spray down with soapy water.  My Murphys law is everytime, no matter how good a weld is, if I do not pressure check there is sometimes a tiny tiny, pin hole, or the crack runs, do to age.  Sometimes the oil gets into the pores of the steel and thus a tiny pin hole.Last edited by wedooit; 05-03-2013 at 04:50 PM.Reason: adding ore infoMiller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:It's about time you did some REAL work!Very nice, as always."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Nice work as always Hey at least he was  nice enough to dismount it clean it and bring it to you i never find those guysThey always call me to fix them by laying in the puddle of oil and do it now they're losing money with it settingBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:The field repair weld didn't look that bad..... except for the split down the middle......Other than possibly not removing paint...... the weld that broke looked like it was done by someone who knew something about welding......Question is...... since it was done in the field... likely with Stick....... why did it really fail?......What makes the multipass TIG job in the shop better? (other than it being ZAP of course)......I don't weld in the field..... only stuff in my home garage.........I'm wondering why the original weld failed........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Tanks for sharing!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
GMT+8, 2025-12-29 04:53 , Processed in 0.135302 second(s), 18 queries .
