发表于 2021-8-31 22:57:07 | 显示全部楼层 |阅读模式
what would you guys do with this Attached Images
Reply:Treat it like a car... Bondo! .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I would remove the hardware and sell the rest for scrap..........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Little sand blasting, some 14 ga sheet metal, some mig welding, primer, and finish paint.It can be done. Price a new one and then think about it.I weld on my old mower deck all the time with my 70 amp mig.
Reply:My initial response was going to be nothing, but it isn't as bad as it looks. The  skirt has to be replaced and a bit of the top section.Leo
Reply:Originally Posted by ed macwhat would you guys do with this
Reply:Is it yours ???  you got time , material ? Fix it. The top drive section looks solid. get some sheetmetal and go to town.
Reply:If it were mine - I'm cheap and like making stuff - therefore I'd weld it up For a customer - depends...Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Um I would turn it into a hover craft.
Reply:I'd patch it up and turn it into a boom mower.  I hate mowing our hills...
Reply:Looks like it's been used to "mow" road salt. How thin is the rest of the deck ? It can be "fixed", but is it worth it ?
Reply:laugh and call a landscaper.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I would sell it for scrap , invest the money in a new tec CO, wait till I become a billionaire and start my own space program...that or... invest in human cloning research, clone Angelina Jolie  and Megan Fox ... have an epic threesome oh wait, those are my plans for the future... I'm sure you can fix it--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:I just fixed a SCAG for a friend that looked just like that.  He wanted a repair that wasn't too intricate.  Said the motor had a year or two at most left on it, so wanted it "good enough".So I cut all the rot out and welded 3/16 plate to every thing, including the wheel brackets.  They are no longer removable.  6011 to burn through the rust and grass.  Covered with 7018 and Mig just for fun.Not my finest work by any means.  It was some dirty stuff to weld through.Last edited by Drf255; 05-05-2013 at 08:07 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:List it on Craigslist for 90% retail price and buy a new one. Wait for someone to buy the old one. Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by 7A749In reality, it doesn't look too bad. That is, if the rest of the deck is solid, especially around the bearing races & connection points.If it is, just cut the bad metal out, fit & install new.A lot like a rotten moldboard on a snowplow. They generally look a lot worse than they are & once you get the bad metal off, it's not too bad.Usually..............
Reply:Upon second look, it is red. Repair and paint BLUE   it will last longer.
Reply:Originally Posted by BD1Upon second look, it is red. Repair and paint BLUE   it will last longer.
Reply:Originally Posted by Dualielaugh and call a landscaper.
Reply:Flex Seal, it's like a handyman in a can.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:"Shes dead Jim"..... I'm just kidding. It doesn't look like a lost cause. Id say cut out the steel that's beyond repair and go from there. Make sure the steel you put back in grabs onto something solid and go from there. Should be a worth while fix1982 Lincoln SA 2001980 Lincoln SA 2501996 Lincoln SA 2501994 Lincoln Ranger 82005 Lincoln Eagle 10,000Millermatic 211 MIG
Reply:What would I do???I would charge $250.00...ESAB Migmaster 250Ltec ST23 spoolgunMiller Passport
Reply:Think I would agree with pretty much everyone else.If it's just the front and yours fix it.  If it's extra make a pull behind or offset mower.If it's a customers think it would be worth it if they want to pay.But this all comes down to is the front the only bad part.
Reply:Originally Posted by weldermikeFlex Seal, it's like a handyman in a can.Originally Posted by SquirmyPugList it on Craigslist for 90% retail price and buy a new one. Wait for someone to buy the old one.
GMT+8, 2025-12-28 23:30 , Processed in 0.129261 second(s), 18 queries .
