Welding and electromagnetic field
发表于 2021-8-31 22:57:07 | 显示全部楼层 |阅读模式
Was doing some work for a friend the other day, a lot of cutting with the plasma cutter,grinding and welding when I noticed something on my patio. All of the metal from grinding aligned around the ground wireI thought this was pretty coolLet's discuss.Last edited by Steelwill; 05-05-2013 at 03:47 PM.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Interesting.Weve discussed magnetic forces om this site before in the context of arc blow affecting DC weldingHobart Stickmate LX235AC/160DCRanger 305GVictor 315 O/A rigHope to acquire in the next couple of years: Hypertherm PM45 and Dynasty 200DX
Reply:My buddy's Syncro 300 in pulse mode will make the lead on the hanger, dance."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I have a buddy with on of those defibrillators who is always in the shop talking mess. I told him I was going to lay the leads on the floor and lure him in the middle and turn the welder o on and trap him, because he is not suppose to be in a electromagnetic field. But I never actually saw proof of till then.Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Originally Posted by Stick-manMy buddy's Syncro 300 in pulse mode will make the lead on the hanger, dance.
Reply:On a directional bore job that I was working on, they used a Lincoln Ranger 9 and a junkload of welding cable. They took the cable, connected it to he + lead and ran it around the jobsite start and made loops around it, then ran the lead directly back to the - lead. It was a loop of cable running from positive to negative. I thought to myself how I would never do that to MY Ranger 9. All they were doing was creating a magnetic field for the computer to track the head of the bore tip. Interesting stuff. A short time later someone showed up on the job site at night and stole the welding cable. OUCH!!!! That was a TON of copper.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:How much did you get for all of it?.Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
Reply:I've heard of a job site prank of coiling leads around tools then throwing the tools up to the duct work. Never actually seen it done though.
Reply:Originally Posted by Joker11A short time later someone showed up on the job site at night and stole the welding cable. OUCH!!!! That was a TON of copper.
Reply:Originally Posted by MinnesotaDaveThat is way cool Dave J.
Reply:I saw a guy fail the DOT bridge test because of Arc Blow, a good way to waste $180
Reply:Hey Stick-man - that is a great video I will be forwarding that one on to our science teacher.  Science in action is always way better than out of a textbook. Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Our old stud gun at work does some wild stuff if you leave the leads coiled while shooting studs. That's how I magnetize my screwdrivers. Works every time.
Reply:Originally Posted by SteelwillWas doing some work for a friend the other day, a lot of cutting with the plasma cutter,grinding and welding when I noticed something on my patio. All of the metal from grinding aligned around the ground wireI thought this was pretty coolLet's discuss.
Reply:I had a very large (over 50 feet in length) pressure vessel on one project that became heavily magnetized at the weld prep.  We had wrapped leads around it in an attempt to demagnetize it, and when you wrapped it much like you would a Helmholtz coil, you could actually get a piece of filler metal to vibrate like a tuning fork when you stuck it through the root opening.
GMT+8, 2025-12-29 01:13 , Processed in 0.095926 second(s), 18 queries .
