Miller alumapro compatable with Lincoln 256
发表于 2021-8-31 22:57:04 | 显示全部楼层 |阅读模式
Might be a dumb question but Is it easy enough to get these 2 to work together? Just curious I found a good deal on the pushpull Jeff
Reply:That might be a question for Miller.But personally I would not think so unless you disable the wire drive. AlumaPro compatible migs use the primary drive for assist only. And the last thing you want is to only pull at the gun. It will last about as long as a Chinese welder.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I would call mk products and get their educated advice. they are very willing to help over there.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
GMT+8, 2025-12-28 23:30 , Processed in 0.124150 second(s), 18 queries .
