is their such thing as bad argon???
发表于 2021-8-31 22:57:02 | 显示全部楼层 |阅读模式
just bought a everlast power pro 205 from a friend and have been welding on aluminum for a few weeks trying to get better at it. i have been doing all my welding on 3/8 thick aluminum plate not sure what type it is. I have been having pretty good results(well for a first timer lol) i have been spending about 2 hrs every morning for about 2 weeks trying to get it down. i was getting good welds with it and went through a couple of tanks of argon the small bottle and then i traded it in for a large bottle so i wouldnt have to go the the welding shop as often and since i hooked it up i cant get a good weld one...so is their any way to gt bad argon?? and if so how do you know if it is?? i will post a few pics later on tonight thanks in advance..
Reply:Yes, you can get one or more “contaminated” bottles.  But other issues will/may give you the same symptoms.  The easiest way is if you’ve not punctured the argon line or changed ANYTHING is to change the bottle.  But there have been documented repeated issues from the same LWS on contaminated argon.  Good Luck!!  Let’s see some weld pictures.Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
Reply:Originally Posted by Grandslam99Yes, you can get one or more “contaminated” bottles.  But other issues will/may give you the same symptoms.  The easiest way is if you’ve not punctured the argon line or changed ANYTHING is to change the bottle.  But there have been documented repeated issues from the same LWS on contaminated argon.  Good Luck!!  Let’s see some weld pictures.
Reply:Originally Posted by crawler07thanks grand slam, should i be expected to pay for the new argon fill? or should i ask for a free refill? and im going to the same LWS as the other one in my area is run by some shady cats.
Reply:heres a pic of some welding on the same thickness aluminum that im having trouble welding since the new tank.these welds were done on the edge and the ones im trying to do now are on flat and it just isnt working fro crap and i havent changed a single setting on the machine aside from the bottle..photobucket is being a real pain in the arse but i will post a pic of the current welds with the new tank as soon as i get them uploaded..thanks for the help guys
Reply:ok got it! heres the nasty welds that are screwing up my project....
Reply:we get batches of bad gas on occasion. it is important in our work because alot of our clients come to us for the bright shiny stainless steel welds. just make sure they don't give you another bottle with the same batch number.'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
GMT+8, 2025-12-29 01:12 , Processed in 0.103687 second(s), 18 queries .
