yus i finnally got my new saw
发表于 2021-8-31 22:56:56 | 显示全部楼层 |阅读模式
here it is.http://www.makita.co.nz/products/detail.lsd?item=2414NBim so excited about when i get to use it.also it came with 11 discs free. it was ment to be 10 but they must of forgotten about the one that was on ithttp://datingsidorsingel.com/
Reply:The sparks  will be fly-en nowNice saw
Reply:i get to test it out today. it will definatly be better than my old saw which didnt even cut square let alone fasthttp://datingsidorsingel.com/
Reply:Nice chop saw, did you buy it online?  Where is the best source for Makita products and, if you don't mind, how much did it go for?  Thanks in advance.
Reply:i got mine from a local powertool shop. it was on special with the blades and i paid $420 nz dollars. ill do a quick search for places that sell makita in the us if you wanthttp://datingsidorsingel.com/
Reply:just go to www.makita.com and then where to buy, then type in your zip code and it will try to find a local dealer. also you can buy the tools online there. hope this helpshttp://datingsidorsingel.com/
Reply:Originally Posted by cheeseclipjust go to www.makita.com and then where to buy, then type in your zip code and it will try to find a local dealer. also you can buy the tools online there. hope this helps
Reply:any time. im glad to helphttp://datingsidorsingel.com/
Reply:I have that same saw and it has worked quite well for me.  It tends to bog down a little when finishing off the bottom of 3.5 inch x 1/4 square tube but it definately gets through it.I love it for small stuff and for shooting sparks at the cat when he cruises through the garage.   MichaelMillermatic 25115" Rockwell Drill Press10" Logan Lathe5hp - 2-stage 80 Gallon CompressorHome Made Sand / Soda Blaster
GMT+8, 2025-12-28 23:31 , Processed in 0.073682 second(s), 18 queries .
