Need help to ID a machine
发表于 2021-8-31 22:56:45 | 显示全部楼层 |阅读模式
Hello all,I've been lurking for quite a while & want to than you all for the great info you share all the time! I've been looking for a second hand mig for a while, & based on what I've seen read here, I want at least 180 amp 220 volt machine (still expensive used for a cheapskate like me).I am just a hobby welder (bicycle builder) & have traded my way up from an 80 amp big box stick, through a lincoln tombstone, up to a miller thunderbolt xl ac/dc machine, but am still coveting a small mig, since I doubt I'll ever weld thicker than 1/4.Now the reason for speech, I need help identifying a used 220 volt mig someone is offering. It came with a garage he bought & the name is warn off. It's about 30 min. away so I'll probably go have a good look & test it. From the photo below it seems to be miller blue.So  hopefully someone can help identify it.ThanksPaul Attached Images
Reply:Looks like a Millermatic of some sort.  35 maybe.Tim
Reply:I agree with pinhead, looks a lot like a MM35 I inquired about here sometime back. I thought it was a 200 but no such luck. Looking back on it I should have bought it anyway. http://weldingweb.com/vbb/showthread.php...51#post3693751
Reply:I'm going with MM35 as well. I owned one quite a few years ago. It was a great machine. We used it hard every day for 5 months while building a sail boat marina. I gave it to one of the hands after we were done. Wish I would have kept it now.
Reply:Thanks guys, I guess I'll have to look it over carefully. Where is the serial number located?
GMT+8, 2025-12-28 23:48 , Processed in 0.167427 second(s), 18 queries .
