Tank Date Codes
发表于 2021-8-31 22:56:44 | 显示全部楼层 |阅读模式
Hello , I just purchased a hobart beta-mig along with 2 tanks. 1 argon, 1argon/co2 mix , Im in NY and would like to determine the date code.they are 300cf tanks based on linde's websitethe tanks are stamped first tank DOT 3AA 2400T 749913 LINDESecond tankDOT 3AA 24002558A161
Reply:Did you search the topic?A quick one came up with this http://weldingweb.com/vbb/showthread.php...cylinder+dates and I know it's been discussed in a number of other threads as well.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:There are no date codes in what you typed.  The 2400 after the DOT 3AA is the service pressure.The T 749913 is likely a serial or asset number and only means anything to Linde.There should be some numbers followed by a + and maybe a star.Pictures of all stampings on these would be helpful.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by duaneb55Did you search the topic?A quick one came up with this http://weldingweb.com/vbb/showthread.php...cylinder+dates and I know it's been discussed in a number of other threads as well.
Reply:I've never seen one without a date. Unless they are brand new and somehow made it out without a hydro.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:in my laziness I did not rotate the tanks or put on my glasses
Reply:Cool. The dark one is good for 6 more years. The blue/green one is out.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:what is the"plus and star" signify?
Reply:The plus means it can be overfilled by 10% and the star means it is a 10 year test (instead of a 5 year test).GravelThe difference between theory and practice is that in theory there is no difference.
Reply:thanks, Gravel, I guess that means 300 + 10 %= 330CF
Reply:The oldest bottle I had or the first hydro date was in 1947. I gave it to my friend in so cal when I left. He's still using it. Yes 330cf. Some will fill it to that some won't. Your prolly gonna pay for 330cf whether you get it or not. Make friends with your supplier.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by GravelThe plus means it can be overfilled by 10% and the star means it is a 10 year test (instead of a 5 year test).
Reply:Originally Posted by InsanerideThanks, I was going to look this up because I thought my tank was out of date 4  98 +*. I take it that means it expired six years ago. Its a practically full tank of Helium. I guess I should hurry and use it.
GMT+8, 2025-12-29 01:12 , Processed in 0.096722 second(s), 18 queries .
