Cebora MIG 140 generating weak arc
发表于 2021-8-31 22:56:43 | 显示全部楼层 |阅读模式
hello,New to the forum, if I can DIY something i will. Welding lies along w/AC as my areas of lesser expertise. My MIG has recently gotten weak, not producing a arc strong enough to make any penetration at all even attempting a tack weld. just had the skins off and connections all appear solid, set on 3 [scale 1-4] it fails to do much on a mild steel sheet .035" thick. same mild steel wire ive always had.thanks for any help!
Reply:Open her up and make sure everything is tight. Could have a loose connection. Also check out the diodes on the rectifier and see if any are burnt.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I second that. Diodes or rectifier.
Reply:Awesome, makes sense. Hope parts on these a Italian jobs are available.Thanks!!!
Reply:Those things are garbage..........
Reply:They are better than a HF welder.
GMT+8, 2025-12-28 23:31 , Processed in 0.096666 second(s), 18 queries .
