Welds of Awesomeness
发表于 2021-8-31 22:56:35 | 显示全部楼层 |阅读模式
So I got the machine smokin'.  I'm cruisin'.............it's almost about sorta maybe done  I'm seein' good things in my future   Maybe Lincoln might just send me that SAE 300 to demo.Lay the part up, take a look at it, and...............................Need a closer looksee ya say?????????  Methinks I'm gonna have to get the razor wheel out in the morning to do a little wee minor adjustment.  I've just about had enough for one day"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Maybe it's them fancy *** new googly google goggles"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I'll take a guess that the hinges of unknown metallurgy with some brass plating did not weld so nicely.Briggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
Reply:Hinges are upside down.Or inside out..Depends on how you view it....zap!Last edited by zapster; 05-01-2013 at 06:28 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:NFG, Not Functioning Good.......Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by WinmacI'll take a guess that the hinges of unknown metallurgy with some brass plating did not weld so nicely.
Reply:Those are regular door hinges and are plated brass not solid brass. Go look at your door in your house haha.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:I don't know who else locally has them, but Best welding supply in Tulsa, on southwest BLVD just south of the river has some really nice weld on type hinges.  Very reasonably priced I think.  From I think 1 1/2" long to 8" long.  The small ones are rated for I want to say 125 pounds a piece, but I'm not positive on that.  That's the hinges I'm going to get for the boxes on my rig if we ever get done on this job and I have a chance to build it.-------------------------Chemetron AC/DC 300 HFSnap-On MM300L Lincoln SP140 Lincoln AC/DC 225g Lincoln SA200 Lincoln SA200 Miller Bobcat 225GVictor torchesH&M and Mathey beveling machinesMcElroy Plastic pipe fusion
Reply:I noticed today that Menards has bare steel hinges that can be welded on in several sizes.  You may try you local big box or hardware store.  A farm store may have them also.My name's not Jim....
Reply:Originally Posted by zapsterHinges are upside down.Or inside out..Depends on how you view it.
Reply:The hinges are ok, just some sort of brass colored plating.  Package says "Bright Brass Finish".  Sorta like the "honey like spread" they give you for your biscuits at KFCThe story on the hinges.  It was Sunday, the LWS was closed, and Wally World was all there was.  They had these in the "brass" flavor, and the unfinished steel flavor, but they only had one in the unfinished steel.  So I got the fancy ones  For $2.47 apiece you know they ain't brassYou can see where the coating burned off.  Ok, ok, ok......shoulda ground the coating off first, but if I can weld over rust I oughta be able to weld over a "brass like coating"  (you really shouldn't do this)Anyways..........back to some welding.  (Cold snowy day in MAY)  And some Southern Soul Searching.Personally, I'm about to throw this stinking wire welder into the ditch.  I'm tired of constantly trying to dial it in.  I see why a lot of wire guys spend half a day fretting with their machines.  YEAH I'VE SEEN IT, AND SEEN IT DONE BY SOME REALLY GOOD WELDERS.  I'm not a good welder.I mean lookit!!  The welds on the hinges are slightly too cool.  A bit high in profile, and the toes not really well wet in on the heavier metal.  The backside of the heavier 11ga floorplate is blued where the welds were run, so you know there's some heat in there, but it looks slightly too cold.Now for these.............This is a completed deal, all the welds done.  14ga again.  The horizontal butt weld is run at voltage tap 1 (whatever that is), and wire speed 10 (whatever that is).  The horizontal fillets are run at voltage tap 2, and wire speed 15.  All the flat fillets are run at voltage tap 2, wire speed 20.  NOW THIS IS JUST FLAT ASSED STUPIDThis is a partially completed deal (horizontal fillet still needs doing).  The uphill is voltage tap 1, wire speed 10ish.  HOLY CRAPOLA!!!!!!!!!!!!!!!!!!!!!!!!!!!And I can tell you that the next time I use this stupid machine, maybe a month from now, I'll have forgotten all the settings unless I write them down.  IDIOTIC.I'm spending half my time traipsing back and forth between the machine, and the steel  I've about had it with this sh##, I'm going back to turning the stupid machine up to the high range, and just changing travel speed to keep from burning thru, and call it a day.  This is just plain stupid.AND ON TOP OF THIS.........THE STINKIN THING WILL CHANGE PERFORMANCE WHEN IT'S RUN HARD FOR A WHILE!!!!!!!  I remember when I was making about 6 or 8 corral panels, and ran the stupid machine hard all day long.  Weld after weld, non stop.  The crappy thing started to run colder welds the hotter the machine got.  It didn't throw the internal safety breaker, it just started to drizzle like an old man taking a whiz!.  By the end of the day I had the thing turned up to the max just to keep making welds.  CRAP, PURE UNADULTERATED CRAP.So, what's the alternative???????????????????  Run the LN25, AND BURN $4.00 A GALLON GASOLINE FOR 10 HOURS!!!!  Just to get a decent duty cycleOoomph"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yes, run the LN25 and have sanity for the low low cost of 4 bucks a gallonDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Oh yeah, the thing that is wrongI welded the left and right tabs in the wrong place  Somewhere along the way, mad as a hatter, ready to kill anything in sight, I measured wrong"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I was going to say the hinges were not centered on the tabs. I saw that right away, cause I done it myself, many times :P!Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Something I've noticed with my MIG welder is it likes a really good ground.  I also upgraded the ground clamp and the wire size used for the ground.  Wherever the ground clamp goes, I make sure there is nothing but bare steel, no rust, mil scale; nothing but clean metal.  The other thing that I found that really helps is having the metal I'm welding as clean as possible, no rust, mil scale, or coatings of any kind.  Its only a 180 amp Lincoln welder, and I want to give it a fighting chance.  GarDisclaimer: 2nd semester welding "student."Lincoln Electric, Power MIG 256Hypertherm Powermax 45 Miller Dynasty 280DXSmith O/A torchGenesis of a welding table
Reply:Originally Posted by farmersammAND ON TOP OF THIS.........THE STINKIN THING WILL CHANGE PERFORMANCE WHEN IT'S RUN HARD FOR A WHILE!!!!!!!
Reply:Originally Posted by farmersammThe hinges are ok, just some sort of brass colored plating.  Package says "Bright Brass Finish".  Sorta like the "honey like spread" they give you for your biscuits at KFCThe story on the hinges.  It was Sunday, the LWS was closed, and Wally World was all there was.  They had these in the "brass" flavor, and the unfinished steel flavor, but they only had one in the unfinished steel.  So I got the fancy ones  For $2.47 apiece you know they ain't brassYou can see where the coating burned off.  Ok, ok, ok......shoulda ground the coating off first, but if I can weld over rust I oughta be able to weld over a "brass like coating"  (you really shouldn't do this)Anyways..........back to some welding.  (Cold snowy day in MAY)  And some Southern Soul Searching.Personally, I'm about to throw this stinking wire welder into the ditch.  I'm tired of constantly trying to dial it in.  I see why a lot of wire guys spend half a day fretting with their machines.  YEAH I'VE SEEN IT, AND SEEN IT DONE BY SOME REALLY GOOD WELDERS.  I'm not a good welder.I mean lookit!!  The welds on the hinges are slightly too cool.  A bit high in profile, and the toes not really well wet in on the heavier metal.  The backside of the heavier 11ga floorplate is blued where the welds were run, so you know there's some heat in there, but it looks slightly too cold.Now for these.............This is a completed deal, all the welds done.  14ga again.  The horizontal butt weld is run at voltage tap 1 (whatever that is), and wire speed 10 (whatever that is).  The horizontal fillets are run at voltage tap 2, and wire speed 15.  All the flat fillets are run at voltage tap 2, wire speed 20.  NOW THIS IS JUST FLAT ASSED STUPIDThis is a partially completed deal (horizontal fillet still needs doing).  The uphill is voltage tap 1, wire speed 10ish.  HOLY CRAPOLA!!!!!!!!!!!!!!!!!!!!!!!!!!!And I can tell you that the next time I use this stupid machine, maybe a month from now, I'll have forgotten all the settings unless I write them down.  IDIOTIC.I'm spending half my time traipsing back and forth between the machine, and the steel  I've about had it with this sh##, I'm going back to turning the stupid machine up to the high range, and just changing travel speed to keep from burning thru, and call it a day.  This is just plain stupid.AND ON TOP OF THIS.........THE STINKIN THING WILL CHANGE PERFORMANCE WHEN IT'S RUN HARD FOR A WHILE!!!!!!!  I remember when I was making about 6 or 8 corral panels, and ran the stupid machine hard all day long.  Weld after weld, non stop.  The crappy thing started to run colder welds the hotter the machine got.  It didn't throw the internal safety breaker, it just started to drizzle like an old man taking a whiz!.  By the end of the day I had the thing turned up to the max just to keep making welds.  CRAP, PURE UNADULTERATED CRAP.So, what's the alternative???????????????????  Run the LN25, AND BURN $4.00 A GALLON GASOLINE FOR 10 HOURS!!!!  Just to get a decent duty cycleOoomph
Reply:Is that a 110v Hobart bicycle welder attached to that cheesy ground clamp? Maybe you should start using your real welding machine again?   When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:Sam,Most of the issue with the lap joints on those hinges seem to be possibly caused by poor bead placement. The beads look to be placed way to far over onto the hinge. Did you have the voltage set to tap 4 when welding on the hinges?Considering the size of tractors you own and the type of project you tend to take on, I've been trying to understand for quite some time why your wire unit is a light duty under powered 120 v 140 amp unit. A Hobart Ironman 230, or even a Handler 210 MVP would be a much better choice for most of you applications.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Can't blame the machine. Some joints are cold and others are just inconsistent or have bad endings. Nothing more time under the hood won't fix. Try pausing a little longer before you pull off the end of a bead.It also helps if you don't weld mad.  haha
Reply:The lincoln 175+ would act like the current was dropping off as I neared the duty cycle which I hit many times..  never been an issue on anyy of the 250+ amp machines I have owned.     I can definitely see it as an issue on that machine you r using ...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:"Welds of Awesomeness"?I see that you've caught on to what great fun it is to refer to everything as "the ___ of awesomeness"I thought that was my deal, but... Hahaha....(Okay, I saw that picture on FaceBook and wanted to use it somewhere... )[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Yeah, what he said. Get a decent machine. BTW, Hobart ain't one of em.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Yeah, what he said. Get a decent machine. BTW, Hobart ain't one of em.
Reply:Originally Posted by jamesyarbroughCan't blame the machine. Some joints are cold and others are just inconsistent or have bad endings. Nothing more time under the hood won't fix. Try pausing a little longer before you pull off the end of a bead.It also helps if you don't weld mad.  hahastick welder = one control dial/knob to adjust (amperage)  You need to have the right amperage for the rod (size and type) to burn well, as well as slightly adjusting the amperage up/down depending on weld position (vert up, vert down, overhead, flat, etc) and slightly on material thickness.  Manual 'adjustment' of travel speed based on watching the puddle melt into the parent material and fill in where you are putting the weld.wire feed welder (FCAW or GMAW) = two dials/knobs to adjust, voltage and WFS (amperage).  Those two settings have to 'agree' with one another for the wire to run 'right'.  You need to adjust the voltage and amperage based on the wire type and size, as well as the material thickness of what is being welded.  For a certain wire size and type, there is usually a range of voltages that will work with a range of amperages (WFS).  But generally, you have to go to a higher voltage setting for a higher amperage setting.Quick setting reminder for wire feed welder.  RTFM or check the parameter label on the machine and set those parameters to start with.  Then make -small-  adjustments from there as needed/desired.Generally, pick the desired amperage (WFS) for the workpiece thickness (1 amp per 0.001 material thickness) and then set the voltage that goes with that WFS (for that thickness and type of wire).Voltage setting too low = wire stubs into workpiece and pushes the gun away from the workpieceVoltage setting too high = unstable arc with spatterSet the voltage halfway between the two ranges.  The best laid schemes ... Gang oft agley ...
Reply:James,My overpriced Lincoln Ranger 9 and LN-25 that I bought in 1997 is still turning and burning. That LN-25 has NEVER been repaired or serviced. I wish I could say that about the Ranger 9. But what happened to it was a complete mistake. I had it on the trailer WITH THE FABRIC COVER ON IT heading home from a job. As I pulled away, a box shifted and hit the start switch. The engine got hot enough to de-magnetize the ignition trigger. But the engine and welder ran perfect after replacing the wheel with the magnets on it. I don't think it would be fair to knock the machine for a human mistake like that.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by DanFor home hobbyist or farm use, I consider Hobart's Handler 190, Handler 210 MVP, and  Ironman 230 all a solid unit for the application.Hobart has recently switched to this wire drive in their Handler 140, 190, and 210 MVP.
Reply:Originally Posted by Joker11James,My overpriced Lincoln Ranger 9 and LN-25 that I bought in 1997 is still turning and burning. That LN-25 has NEVER been repaired or serviced. I wish I could say that about the Ranger 9. But what happened to it was a complete mistake. I had it on the trailer WITH THE FABRIC COVER ON IT heading home from a job. As I pulled away, a box shifted and hit the start switch. The engine got hot enough to de-magnetize the ignition trigger. But the engine and welder ran perfect after replacing the wheel with the magnets on it. I don't think it would be fair to knock the machine for a human mistake like that.
Reply:Originally Posted by jamesyarbroughWell they are better than them overpriced lincolns with PLASTIC wire drives. I guess not everyone can afford a miller, so we just get the next best thing.
Reply:Originally Posted by Brand XJust so you know.... Sam has time of a Lincoln C-300 Powerwave. I think he liked his 140 Hobart better..Old dog new tricks thing, I believe.
Reply:One dial on  tuning C-300/ I liked the arc on the the C-300, just not as well as other machines.Like the Thermal-arc I kept. I have two mig machines, and that is all I want or need.. His main problem is seeing the weld bead. He just has not done enough gas shielded welding to get a good feel for it. (Too much wind)I sold the C-300 to a buddy that uses it's features with 50 ft push/pull Perfect machine for him..The 252, and 300 went in a package deal to a guy stationed in Afghanistan. Was a interesting Craigslist transaction. He will be back in a the states in 1.5 years, and the machines are waiting for him. Wife bought a house over here at the same time. He got the best deal on Craigslist, because my stuff is mint, and welds/works perfect..By the way, he has a great wife, and was all for this deal.. She is even making some machine covers in yellow to surprise him. PS, this last 300 multimaster was the sweetest one of the 3 I have owned.  I like the twin feeder setup on the Thermal-arc, and the compact overall unit. Suits my needs a bit better. Sure had great arc starts. Something I really had to work on the Thermal to get there. Could not go wrong keeping either one..Last edited by Brand X; 05-11-2013 at 11:21 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:I have a 180-200A wirefeeder. I leave the voltage on 8-10 for almost everything and just adjust wire speed from 40 to 80%. I can get 100% pen on 1/8" flat square butt welds with maybe a 1/32" gap. Welding some 1/8" 1x1 angle to 1/8" tread plate I got full pen at 7-40 because the top of angle is j-beveled. Welded another section of angle sitting flat on the plate mating at 90 to the other angle rails, I ran 8-60 and burned through well enough to be happy.. I almost never change settings since the only time I really use mig is for 1/8 to 1/4, same brand .030, same 100% co2. I did upgrade my gun a few years ago and it was the best investment I've ever made. Tweco q300 15' to replace my m-10 gun with Centerfire consumables. I had to get creative with a razor knife but I made it fit, and it made me love my mig again.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
GMT+8, 2025-12-29 01:22 , Processed in 0.106818 second(s), 18 queries .
