push pull aluminum whole set up?
发表于 2021-8-31 22:56:29 | 显示全部楼层 |阅读模式
I tig most of my aluminum so far, but have some bigger projects on the horizon and have to look into a push pull system.I have a spoolgun and a TA 400MST power source.can i get by with adding an optima pulse unit ($1K ish) and then just adding a push pull feeder later?or should i be looking at one of those fancy new power supplies that do the pulse on pulse?I know which is cheaper!!thanksG
Reply:for serious volume you can't beat the time savings and ability to articulate the torch of a cobra push pull torch.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I am a big believer in a turnkey system. I have an MK CobraMig260, and a MillerMatic350P solely dedicated for alum. Pulse on pulse is helpful for sheet alum, but all but useless for plate thicknesses since alum only transfers in spray.The big draw is hotstart and run-in adjustment. The best thing since sliced bread is the new Millermatic350P-Aluminum only. They took out the heavy 4 gear drivebox and replaced it with a 2 gear drive, and omitted parameters that deal with steels, and included easy to set alum setups. It is point and shoot so to speak. Me thinks this is in response to Maxal's new miracle 4943 alloy wire(which I have now and my CobraMig hates but my MillerMatic is dedicated to 5356).Go to Miller's Website and take a look.http://www.millerwelds.com/about/new...-applications-And [ame]http://www.youtube.com/watch?v=TAqDAh5payk[/ame]Last edited by shovelon; 01-24-2013 at 06:05 PM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Have you used the 350 mpa? Lots of fun to use, and fast setup for different jobsDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by turkHave you used the 350 mpa? Lots of fun to use, and fast setup for different jobs
Reply:The beauty of those machines is you can dial the pool to whatever you wantDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Thanks guy's The answer I realy want is how does an optima compare with a 350 mpa?G
GMT+8, 2025-12-28 23:31 , Processed in 0.103175 second(s), 18 queries .
