new help with newly purchased wire feeder
发表于 2021-8-31 22:56:29 | 显示全部楼层 |阅读模式
Bought a hefty cccv feeder to run off my shopmaster 300. Hooked the lead from the feeder to the power supply ran ground and the voltage sensing wire to material to be welded.. pulled the trigger and......nothing... only arc welded with the power supply before.. not sure if the feeders screwed up or not. Check fuses and connection etc.. please help..lol
Reply:Check the fuses, mine had a bad one when I bought it. There are 2 check them both.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-29 01:12 , Processed in 0.100925 second(s), 18 queries .
