For Sale in BC: pick-up truck 5'th wheel rails mount system for engine drive welder.
发表于 2021-8-31 22:56:21 | 显示全部楼层 |阅读模式
Last year I built a system that was designed to hold an engine drive welder roughly the size of a trailblazer or bobcat and have room on the side for bottles or whatever else you wished to put there. This mount system was designed to be a quick release mount, and is designed to securely clip into a truck's 5'th wheel hitch rails (which sit pretty close to flush with the trucks bed) and has about 8" of clearance built in under the platform for a ladder. The whole idea behind this was to be able to remove your welder easily when not using it, but still have a semi-professional mounting system to hold the welder in the back of the truck when heading out to a job. It includes pretty much everything you need to make it work minus a few nuts and bolts (I might even have them, I'd have to check), and it is including the 2'nd set of rails for the truck and the L-brackets, just no bolts. I got about $300Cdn into it and about 20 hours or so, but now that I built my deck I have no need for it so I am putting it up for adoption at $300cdn.  I'll list it in the paper in another week for $350, just giving any local members first crack at it. If anyone is interested in it, I can post some pictures.thanks guys
Reply:Welcome Coal SmokeIF it Catches...Let it Burn
Reply:Thanks Tx. I must admit, I didn't even know that this site existed until I saw it mentioned over at the weldingwiki forums, so I checked it out and it sure seems like a real good bunch of people here
Reply:Thanks,  yeah most of what is over there is also over here.  Just a larger group here.  MOst of these guys are good ole boys.IF it Catches...Let it Burn
GMT+8, 2025-12-29 01:12 , Processed in 0.105881 second(s), 18 queries .
