WANTED: ESAB Control cables
发表于 2021-8-31 22:56:20 | 显示全部楼层 |阅读模式
I picked up an old Linde (ESAB) Trimpower SVI 300 power supply which came with a L-Tec Digimig wire feeder.  I need the two control cables that connect them.  If anyone has the cables around that they don't have a use for I would be willing to pay a reasonable amount for them.  This is the old style Digimig which has two control cables coming into the back instead of one.These are the part numbers I need if they are of any help.ESAB Model 678399 6' Control CableESAB Model 996735 6’ Control CableI would just buy them from a dealer but ESAB seems to think they are made of solid gold or something judging by the price.Thanks,Calvin
Reply:What is the model of the jack (not the unit)? or do you have a photo of the plugs?
Reply:If you go to www.mouser.com, you can probably find a match on the connectors and build your own.  Another alternative is to replace the connectors with more common new ones.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by ctardiWhat is the model of the jack (not the unit)? or do you have a photo of the plugs?
Reply:What you have there is typical of a "cannon plug" (ITT-Cannon is the manufacturer and thats why they call'em cannon plugs & they are widely used throughout the aviation industry). I think there might be other manufacturers, but i hopethat helps a little.  ooh, and the official FAA certified cannon plugs are pretty pricey. I wish you luck.
Reply:One of my bestest ol' buddies is in the welding machine repair biz,,I'll show him the photos and see what he's got or if he can find 'em.
GMT+8, 2025-12-29 01:22 , Processed in 0.071911 second(s), 18 queries .
