airco 350 amp mig need info
发表于 2021-8-31 22:56:19 | 显示全部楼层 |阅读模式
Howdy everyone,    I am new here.   I have an airco mig 350 amp with the push/pull wire feed.  I bought it at an auction but the only problem is it is 3 phase.   I heard you can't run it off a converter and I don't have 3 phase in my garage.   Would anyone know anything about this welder and would anyone want to trade for something?
Reply:That is correct,,one cannot use a "converter" with transformers. That's a good ol' machine, tho. Too bad you don't have 3ph. Post the serial # and I'll try and get you the spec sheet.
Reply:I will get you the serial numbers today,    Thanks for the help.
GMT+8, 2025-12-28 23:32 , Processed in 0.074830 second(s), 18 queries .
