Speedaire 20 gallon compresor
发表于 2021-8-31 22:56:16 | 显示全部楼层 |阅读模式
I am In the western NC near Asheville,  I have a 220/110 Dayton (Speedaire) commercial compressor for sale. New belt,new wheels , new leveling feet, all new plumbing including pre set pop off safety valve,All guards intact , Its been tested to 175 PSI but I set the switch to 90/psi on  ,135/psi off) as to what is what rated . The grainger folks told me to up the switch to 170 all day long and no problem, but most air tools are rated 90/100 max so I left it as it was made for.Will hold pressure with absolutely  no leaks. Aside from a new paint job, rings, and new brass pulleys , all has been updated. It has new belt, new guage,fresh oil,all new pipe fittings, and a female standard quick disconect. ABSOLUTLY NO LEAKS! It has a custom made handle bar (made to protect the piping, guage, ect). It is only single stage, but very quiet and fast recharging. To run 110 volts, you need a dedicated 30 amp breaker. 220 it doesnt even dim the lights.... The motor alone is $230 new. WW grainger stocks all needed parts. New it is $450.00, I am asking $300.00It does not have the capacity to  push my 4'x4' sand blasting cabinet for any long amount of time. You can call me at 828-645-8397 for more info if needed ,  ask for Ed.
GMT+8, 2025-12-29 01:13 , Processed in 0.098617 second(s), 18 queries .
