tailgate work bench.
发表于 2021-8-31 22:56:07 | 显示全部楼层 |阅读模式
Did this for a customer over the weekend.Took off fiberglass barnstyle doors.Wanted a tailgate /bench.Also did bumper had nothing.This is all on a dodge 2500. Attached Images
Reply:That looks pretty good. What business is he in?
Reply:Nice work! That will outlast the truck for sure. Mount a pipe vise on the bench and a bench vice on the bumper!! jkMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Originally Posted by BobThat looks pretty good. What business is he in?
Reply:Is there anything other than gravity holding the arm to the bumper?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterIs there anything other than gravity holding the arm to the bumper?...zap!
Reply:Nice! Although, a waste of talent and steel on a dodge! Also, is there anything locking the drop arm when the bench is in the up position? Because I can just imagine hearing it clunk when taking off from a stop."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:The weight of the bench is all the holds the arm to the bumper good point.You are not goint to hear that arm rattle over the cummins engine under the hood and the loud exhaust pipe.Going to mention to guy he may want to drill thru the angle on arm and tap/die the bumper and put a bolt with wing to tighten by hand thru bumper.
Reply:Is that bumper made from diamond plate closing a piece of channel?  Does it have a way to drain water when rain gets around the intermittent welds?
Reply:Nice, round the corners, they hurt."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:nice use of space and every inch counts on a rig
Reply:good job.
Reply:looks like the stiff arm support extends past the folcrom of the hinge and impacts the underside of the top preventing it from over extending and thus eliminating the need for a retainer at the bottom. as for the bumper, my guess is the bottom/back is open.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by mstyerIs that bumper made from diamond plate closing a piece of channel?  Does it have a way to drain water when rain gets around the intermittent welds?
Reply:Originally Posted by ThorsHammerlooks like the stiff arm support extends past the folcrom of the hinge and impacts the underside of the top preventing it from over extending and thus eliminating the need for a retainer at the bottom. as for the bumper, my guess is the bottom/back is open.
Reply:Originally Posted by MondoI had to read this and go back and refer to the photos at least three times before my feeble mind could grasp what you are sayimg.   In the final analysis I agree with your most astute observation.  The support arm cannot swing downwards far enough for the table to drop.  What can happen is a severe bounce could cause the table and arm to swing upwards just enough such that if the time it takes for the arm to return to the down position is longer than it takes for the table to dop the support arm could slide across the top of the bumper causing the table to drop below horizontal.  Not likely in use, but a drive-off with the table in the horizontal position could lead to this.- Mondo
GMT+8, 2025-12-29 01:13 , Processed in 0.071539 second(s), 18 queries .
