Hi,I just ordered a Hobart 190 with a Spool Gun. I need some info on what type of gas I need to use with it ?.. I do plan on welding aluminum too!I've read where some here are using a % of Argon and a % of another gas in the same cylinder. Am I correct on that ? I'm sorry, but I have never had a welder before that used gas, and I've never welded with gas before.Go ahead and laugh at me if you want to, I really don't care.I own my oxygen & acetylene tanks and they're the large ones.. I now need to locate me a cylinder for my welder, and I'm sure I can get what I need in the morning, but I have another question.What size cylinder should I get ?Any other info that anyone has would help.Thanks!
Reply:You can't mig weld alum and steel with the same gas. Alum will require 100% argon. Steel usually requires either an argon/ CO2 mix like 75/25 or 80/20 ( "normal" mix varies by gas supplier) for small migs like yours, or 100% CO2..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If you don't get your bottles delivered get whichever size you can lift yourselfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by CopperheadGo ahead and laugh at me if you want to, I really don't care.
Reply:Get the biggest tank you can carry. Refills are cheaper in larger volume.I'm no weakling, but I have a 244 CF bottle and it's not too easy to lift by myself. In a few years I'll need help with it. The 125 I have is really easy.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Grab a 125 cuft of 75/25 or 80/20 ar/co2 (whichever your welding shop carries) AND a 125 cuft of straight argon. Reason I suggest this is because prices are always on the rise. Three years ago a 125 cuft bottle base price was $170 for me. Now the base price is $230. I don't know how things are for you over there, but in hindsight I now wish I would have just bought two back then.Even if you don't plan on lots of aluminium now, later on you might get a tig, and that will require straight argon for either steel or aluminum.
Reply:Originally Posted by OscarGrab a 125 cuft of 75/25 or 80/20 ar/co2 (whichever your welding shop carries) AND a 125 cuft of straight argon. Reason I suggest this is because prices are always on the rise. Three years ago a 125 cuft bottle base price was $170 for me. Now the base price is $230. I don't know how things are for you over there, but in hindsight I now wish I would have just bought two back then.Even if you don't plan on lots of aluminium now, later on you might get a tig, and that will require straight argon for either steel or aluminum.
Reply:Originally Posted by DSWYou can't mig weld alum and steel with the same gas. Alum will require 100% argon. Steel usually requires either an argon/ CO2 mix like 75/25 or 80/20 ( "normal" mix varies by gas supplier) for small migs like yours, or 100% CO2.
Reply:Originally Posted by shovelonDone. At least you got that out of the way.
Reply:Originally Posted by Copperhead I got the Hobart 190 with the Spool Gun at Amazon for a price that I couldn't believe or pass up! |
