Help PLEASE!!!
发表于 2021-8-31 22:56:01 | 显示全部楼层 |阅读模式
Just got a lincoln precision tig 375, haven't tig welded in a few years could you help... what would be the setting to start with:welding 1/8 aluminum to 1/4 base plate fillet weld4043 rod 1/163/32 tungsten#5 cup  just need to know where maybe middle ground is for setting thanks
Reply:Originally Posted by Johny5Just got a lincoln precision tig 375, haven't tig welded in a few years could you help... what would be the setting to start with:welding 1/8 aluminum to 1/4 base plate fillet weld4043 rod 1/163/32 tungsten#5 cup  just need to know where maybe middle ground is for setting thanks
GMT+8, 2025-12-29 01:12 , Processed in 0.072472 second(s), 18 queries .
