Whats the best way to make a half round end on square tube
发表于 2021-8-31 22:55:56 | 显示全部楼层 |阅读模式
Is there any practical way to do something like this without a mill? Attached Images
Reply:I was actually looking at a machine that could do thing like that today. It cost big money and weakened the metal at the bends where it was stretched.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:cut a piece of round bar the thickness of the square tube- that is, if its 1" square tube, get a piece of 1" round, 1" long. Weld it to the end of the tube.Then, the only joints you have to sand out are flat ones- the curvature is established by the round bar.
Reply:apice of pipe or tube fitted in.
Reply:does it have to be solid? material? size (i don't see anything in the pic for reference)... what is it anyway?later,Andy
Reply:Something like that, I just hit it with the scribe and marking marker, to make the half round, then hit it with my 9" disc sander.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:its a part for a piece of fitness equipment, it needs to end up with a nice finish. Doesnt matter if its solid or not, tube would be nice since its easier to cut though. The tube idea seems like it will work pretty good. I guess there will be a a lot of grinding and some filler.
Reply:All good ideas.Just another options, probably not any easier.  cut your half round shape in the tubing without removing the sides.  Then, fold the sides over the half round shape, weld and grind.  Might take some heat.  I make rounded corner on angle using that method.
Reply:Band saw template and finishing sander.
Reply:How many do you need?If you had a few and it was for commercial reasons I'd draw it and get it laser cut...all exactly the same , fast and all exactly correct.A good guess is better than a bad measurement
Reply:Originally Posted by 65535Band saw template and finishing sander.
Reply:You can do multiple passes, just take off a little at a time and finish it with a sander.
Reply:Originally Posted by ztecWhat do you mean when you say laser cut?
Reply:here we go now... if it were me, i'd just follow the steps... however there's probably hundreds of ways of doing this... this is just my take on it.Later,Andy
Reply:Originally Posted by ztecwill a bandsaw do that tight of a turn?What do you mean when you say laser cut? Get the radius cut off the end of a piece of tube and fill it in?
Reply:For a one-off piece, you could whitle it out on a good bandsaw with the right blade(s) and some patience. If you are planning on making more than one I would consider using one of the other suggetions above.  I can make that radius with my 1/8" blade.  To get the long sections straight and for the smoothest cut, I would use my 1/2" blade.  Depending on the material (alum or steel), it may take about a half hour.  I have dry cut 2" thick billet alum on my saw w/ no problem.Hobart 140 Handler w/ gasHyperTherm Powermax 380 Plasmaoxy/acetylene
GMT+8, 2025-12-29 01:21 , Processed in 0.150588 second(s), 18 queries .
