Mig welder?
发表于 2021-8-31 22:55:44 | 显示全部楼层 |阅读模式
I'm sure you guys will slam me for this but looking at a mig welder to weld some rocker panels for my truck. I don't want to go buy a $900+ unit that i'll only use few times. That being said here you can look at this http://www.harborfreight.com/welding...der-68886.htmlWhat all do i need along with that? I need the gas and stuff to go with it correct?
Reply:You'll end up using it more than you think you need it...spend the money once now rather than twice later.
Reply:Just pay somebody else to do it if you don't need a welder.
Reply:Depending on how much welding to you it may take 2 or 3 HF welders. Choose wisely.
Reply:I welded with the mig170 and it was a decent little welder, I am sure the 180 model is better. Get a decent sized cylinder 125cf + and some lincoln wire, Harbor freight mig wire sucks and their flux cored is decent for putting scrap together. Check out youtube for reviews of that welder.
Reply:A friend at work suggested a Hobart. And also mentioned that you'd be surprised on how much you weld if you had one. Looking at prices they aren't too bad and did watch reviews and read some reviews.HF will not be bought. Pretty much read once break they are throw aways.Not a mig welder but would be sufficent for rockers? http://airgas.com/product/Welding-Pr...21&fo_s=gplausLast edited by wishingbig; 10-31-2014 at 12:58 AM.
Reply:Depending on your location, check craigs list. The 110 volt mig are always listed near me. People buy them and either use them for a few hours or decide they don't need a welder. I would not get less then a 140 machine , it's sad  because after you buy a small one you then decide to go larger. You can't use amps you don't have. Here's Tractor supply and Northern, http://www.tractorsupply.com/en/stor...140-mig-welderhttp://www.northerntool.com/shop/too...1413_200471413
Reply:Go used with a major brand then trade up as needed.  Major brand welders lose value after 3-4 years and then stay stable for a loooooong time.  A nice used miller 110 unit will likely sell for what u bought it for in a year or two.  Even if it doesn't, you'll lose much less than buying new and selling used.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Hobarts EZmig is a fluxcore only machine. You will want a machine capable of using gas and solid wire to do a decent job on body panels. The next step up, the Hobart HH 125 is the same size machine, but will accept the gas hook up.FC wire is too hot to easily do thin sheet. You'll want to run .024 solid wire and 75/25 gas to do what you want to.Take a minute to add your location to your profile so we know where you are at. Some one here may know of a deal and pass it on to you if they know you are close. A lot of guys here browse CL regularly. Also another option might be to look into a night class in body shop at a local high school or Votec school. Most are more than willing to let students work on their own projects as long as they aren't going to tie up the shop. You'd have access to better tools and equipment as well as the instructors knowledge to make things go smoother and faster..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I needed a machine for sheet metal on my old cars. I bought the Millermatic 140. I love it. It's perfect for sheet metal. I see used ones on craigslist all the time around me.
Reply:+1 for craigsSent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:Originally Posted by wishingbigI'm sure you guys will slam me for this but looking at a mig welder to weld some rocker panels for my truck. I don't want to go buy a $900+ unit that i'll only use few times. That being said here you can look at this http://www.harborfreight.com/welding...der-68886.htmlWhat all do i need along with that? I need the gas and stuff to go with it correct?
Reply:Originally Posted by mikecwikJust pay somebody else to do it if you don't need a welder.
Reply:I would suggest you get a pro to do it ...But if you're going to do it your self get a little miller 140 a bottle of 75/25 gas and a regulator and a spool of .030 easy grind wireBut practice first on some scrap not the car...and get to where you don't warp the metalwelding sheet metal on cars has a learning curveBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2025-12-29 01:25 , Processed in 0.168342 second(s), 18 queries .
