Row cleaner bracket
发表于 2021-8-31 22:55:40 | 显示全部楼层 |阅读模式
So many members here are great at taking progress pictures of projects. I'm not one of them. I get caught up in the "just get it done ASAP" mentality. Anyway, quick fix to keep the planter rolling. A bracket that supports the row cleaner on my old JD 7200 planter broke during a stretch of good weather. Shot of the finished bracket:And the welds:Bracket was 1/4", cleaned and ground to a sharp point and welded in 2 passes. Even the small fixes deserve to look good.Lincoln Precision Tig 185Lincoln Power Mig 256Hypertherm PM 45Everlast 140STSmith O/A
Reply:You TIG guys  Coulda sticked it, MIG'd it, even O/A'd it, BUT NOOOOOOOOOOO.............GOTTA GET OUT THE OTHER WELDER "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yeah, I could have sticked it... but then I'd have slag. My mig is set up with .045 wire, and that piece would hardly be a tack. Soooooooo, I tig it. Probably because this is an outer row unit and it's possible someone other than me might see it. Any of the inner units and it might be different. Lincoln Precision Tig 185Lincoln Power Mig 256Hypertherm PM 45Everlast 140STSmith O/A
GMT+8, 2025-12-29 01:33 , Processed in 0.072509 second(s), 18 queries .
