H/D truck slides for 2500 lb welder or ?
发表于 2021-8-31 22:55:37 | 显示全部楼层 |阅读模式
Has anyone built a heavy duty truck slide for 2500 lbs?  http://www.truckbedslide.net/ builds one that pictures a Miller Big Blue Air Pak.  Have been told by Highway products, that also build slides for trucks, that vibration will kill the bearings or rollers....true, but rollers and bearings are replaceable items.  (Highway products have a killer box under their custom section!) Just wondering if anyone has built, or has some plans or ideas or???? I have my Miller Big Blu mounted on my deck of my semi tractor, that we built.  Needing to build a Drom box of some kind, to mount above the welder, or house the welder, thus needing a slide system to roll out the Big Blu for service or removing. Thought about mounting the Big Blu on top of a box. this makes it top heavy and the controls are hard to reach to start unit or to turn on airpak.  The box needs to house welding leads, spool guns. air hoses, and all sorts of reels, etc. The other option would be to lengthen the tractor frame, as now I do not have enough wheel base.  I pull a 48 ft. former race car semi trailer as a mobile shop....and of course we mounted the Big Blu on the deck of the tractor....maybe a mistake?????....however we bobtail to jobsites. Just not wanting to make a mistake in design or build again and again.....any help or suggestions would be greatly appreciated!!!! Many thanks!Last edited by wedooit; 05-02-2013 at 03:46 PM.Reason: misspelling
Reply:Here is pictures of what I need to build.... Attached ImagesMiller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:Is that as far out as it slides?  thats a lot of weight to have hanging un supported  from the side of a vehicle. I see a pretty major tipping hazzard if it comes out much farther than that. but if thats far enough out for the crane got grab the lift eye than I think you'd be ok.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Here is another picture....I also could build a slide to house all my reels. Attached ImagesMiller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:Thanks for the reply......I could support the weight with some portable legs.  BUT I don't need the unit to be out of the "box" unless check oil and fuel and change oil filters. etc.  Will build box with plenty of air movement or could put on additional fans.Thanks for your idea!!!!Miller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:Pictures came from truckbedslide.netthanksMiller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:I received a quote and schematic from truckbedslide above like the on the white service truck.  About 1300.00. And will handle the weight as engineered.  Just an update.  thanksMiller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
GMT+8, 2025-12-29 01:24 , Processed in 0.073185 second(s), 18 queries .
