Kayak hanger from re-rod, using t-slot table, pics…
发表于 2021-8-31 22:55:36 | 显示全部楼层 |阅读模式
One of those fun, therapeutic projects. Took an hour to set-up, it’s the part I enjoy…..Last edited by MR_JOSHUA; 05-15-2013 at 02:18 PM.
Reply:Looks like it works well, I have an old cedar strip canoe my late brother made, might be an idea to make something so I can hang it up to store also.
Reply:Originally Posted by MR_JOSHUATook an hour to set-up, it’s the part I enjoy…..
Reply:The vertical bar is a reminder.  When you bump your head into that, it reminds you not to hit your head on the kayak."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Must be.  What was there - 20 seconds of welding? Rebar makes nice, inexpensive project material but at times likes to break at the weld due to inconsistences in hardness.
Reply:MR_JOSHUAIf I had a that table I'd put it in my living room, and be selective about building anything from re-bar when life safety is an issue.Opus
Reply:Originally Posted by duaneb55Must be.  What was there - 20 seconds of welding? Rebar makes nice, inexpensive project material but at times likes to break at the weld due to inconsistences in hardness.Is the vertical piece with the bend just a handle to set and remove the mount?I love the slot table too.
Reply:Awesome garden fence! Makes for nice bottle tree material too.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I would enjoy the setup part aswell if I ahd a great table like that! Nice.
Reply:My only complaint is I think it's a Honda??JF
GMT+8, 2025-12-29 01:33 , Processed in 0.100398 second(s), 18 queries .
