Metal storage rack.........
发表于 2021-8-31 22:55:36 | 显示全部楼层 |阅读模式
I needed something for the longer pieces of scrap I have.........So................ I used some scrap to make a storage rack....... for my scrap..........It's a viscous circle around here.......PICS........ Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I made something like this but when you have pieces that are shorter than the distance you need another place for smaller scrap lolWhat angle did you use? I like how it appears to be Steep enough where nobody walking by an hit their head on it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Nice rack and nice weld too..Wish i have a machine like yours
Reply:The angles were left overs from other projects..... cuts are 45 degrees.......I do have pieces that are too short to span the distance......so I just tossed them on top of the TB on the bottom rack........Good enough and it gets them off the ground........I found a few pieces I forgot I had in fact........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Nice ! Besides my rack I have a 55 gallon drum for pieces. Actually, I got a old golf club bag that I placed inside the 55 gallon drum and put steel in it. Worked out well and makes steel removal easier.. Now I want more free golf club bags.
Reply:Originally Posted by FexalThe angles were left overs from other projects..... cuts are 45 degrees.......I do have pieces that are too short to span the distance......so I just tossed them on top of the TB on the bottom rack.........
Reply:How did you tighten the top fastener?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:A screw using a bit and channel locks..........It took some time on that to get it all the way in the stud.......Bad design on my part......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
GMT+8, 2025-12-29 01:14 , Processed in 0.067904 second(s), 18 queries .
