Dual Shield FCAW / W/ C0 2 with The Millermatic 212 running .045 Wire
发表于 2021-8-31 22:55:30 | 显示全部楼层 |阅读模式
Having  issues runninig this are we are the max of the power spec for this machine.Electrode Positive with 100% CO 2We are running it in the Millermatic 350 P with very good results. Electrode Positive with 100% CO 2The 212 Manual calls for .045 Wire FCAW however the weld is too cold.???Mountain MetalDynasty 200DXCoolmate 1Miller Trailblazer 302 W/ KohlerMiller Suitcase 12VS Wire feederWeldcraft 26 TIG TorchMiller 210 Spoolmate 3035Thermal Dynamics 51 PlasmaVictor O/AJet  7x12 L Cooled Band SawDelta Drill Press
Reply:Check the wire specs to see if you have the correct polarity for that wire.What brand and type is the wire?Last edited by shovelon; 02-03-2013 at 01:06 AM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:The only fluxcore wire listed on the MM 212 door chart, is a self-shielded E71T-11. An E71T-11 self shielded fluxcore runs at a much lower voltage then a gas shielded fluxcore. Honestly, if your 212 is the variable voltage auto-set version I doubt it outputs enough voltage to run a dual shield wire properly, especially with CO².ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by Danespecially with CO².
Reply:You typically have a higher arc voltage with CO2 than with mixed gas, though that seems to be less of an issue with dual-shield than with hard wire. The 212 still just doesn't have enough voltage to run dual-shield except at the lower end of the wfs range. Replace the 212 with something bigger, or just use the 350.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Thanks I had had a feeling we needed more machine for the wire dia.Mountain MetalDynasty 200DXCoolmate 1Miller Trailblazer 302 W/ KohlerMiller Suitcase 12VS Wire feederWeldcraft 26 TIG TorchMiller 210 Spoolmate 3035Thermal Dynamics 51 PlasmaVictor O/AJet  7x12 L Cooled Band SawDelta Drill Press
GMT+8, 2025-12-29 01:12 , Processed in 0.101287 second(s), 18 queries .
