New hose, contamination?
发表于 2021-8-31 22:55:28 | 显示全部楼层 |阅读模式
So, I just bought some hoses (new) for a small oxy/fuel setup I'm putting together.  When I looked at the hose ends, I saw a little brown spot on the end of the cone inside one fitting.  Wiping it, it looked like it might be a tiny bit of grease (not 100% sure).  I know that there are some issues with oil and oxygen... but I'm not sure how paranoid I should be.  Is it safe to just wipe it?  Should I use rubbing alcohol or acetone?  Do I need to worry small quantities of that getting on the hose?Of possible note: I'm not using an oxygen tank, I'm using an oxygen concentrator, so it'll be a pretty low pressure system.Thanks voices of experience!
GMT+8, 2025-12-29 01:14 , Processed in 0.097801 second(s), 18 queries .
