where to get lincoln plazma repaired
发表于 2021-8-31 22:55:20 | 显示全部楼层 |阅读模式
got a line on a lincoln plazma cheep but it doesnt work,dont know whats wrong with it actually i dont even have it yet but i was wondering if it could be repaired or if its even worth the time messing with it
Reply:Maybe work on your bio, to show your hometown. If you'd like to drive to SoCal, I know a welding shop here in Santa Ana that does repairs. But maybe someone closer to you could help you out.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-29 01:33 , Processed in 0.096920 second(s), 18 queries .
