SBL pulley project
发表于 2021-8-31 22:55:18 | 显示全部楼层 |阅读模式
I made this pulley today. I used a single 1/4" HSS bit pointed with a 4" grinder for the grooves and of course carbide to cut the OD's to shape from a chunk of 4" cold rolled steel from ZAP. Turned it on a manderal. All that is left is the key slot...Bob Attached ImagesBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Very nice Bob, thanks for the pics.Every time I use a certain drill-press, I wonder what to do about the slipping step pulley; it is worn out on the preferred groove.Are you taking orders??
Reply:Cool!  That'll give PepBoys something to think about lol!Have a Jeep Cherokee?  Click Here!
Reply:Originally Posted by aametalmasterI made this pulley today. I used a single 1/4" HSS bit pointed with a 4" grinder for the grooves and of course carbide to cut the OD's to shape from a chunk of 4" cold rolled steel from ZAP. Turned it on a manderal. All that is left is the key slot...Bob
Reply:I deleted this post because it was a double post. Computer error.        Sincerely,             William McCormick
Reply:We have a nice automatic keyway cutter at work. Just put the pulley in and push the button...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
GMT+8, 2025-12-29 01:12 , Processed in 0.071719 second(s), 18 queries .
