End Return?
发表于 2021-8-31 22:54:55 | 显示全部楼层 |阅读模式
I am working on a project at work where we are making 3/16 aluminum fillet welds. I am trying to figure out whether or not to end return the welds. do I stand to  gain anything from end returning? Should I not do it? I am looking for some actual published data (AWS maybe?). Any help would be great.Thanks.Rybot
Reply:Two competing viewpoints:AWS D1.1:20002. Design of Welded Connections2.19 End ReturnsSide or end fillet welds terminating at ends or sides ofheader angles, brackets, beam seats and similar connectionsshall be returned continuously around the cornersfor a distance at least twice the nominal size of the weldexcept as provided in 2.4.7.May 2008 MODERN STEEL CONSTRUCTIONWhat Every Fabricator Wants You to Know about WeldingBy Monica Stockmann and Thomas J. SchlaflyDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thanks. I have read much of that already and found it helpful. I think we have decided what to do.Rybot
GMT+8, 2025-12-29 01:24 , Processed in 0.096979 second(s), 18 queries .
