Macro Etch tests for A36- 17-4PH stainless
发表于 2021-8-31 22:54:47 | 显示全部楼层 |阅读模式
we switched from a 309L-16 to a 309L-17 and got better pen..  Anyways these are the photos Attached Images
Reply:No penetration at the root? what process and material dimensions? have a normal pic of the weld?Welding/Fab Pics: www.UtahWeld.com
Reply:Its A36 to 17-4 stainless, using SMAW, each plate is 3/16 thick.. The weld was pretty clean but i dont have a photo of it.  we started with a 309L-16 filler and then changed to a 309L-17 and it worked a little better.  From what I hear the 309L-15 is the best bet for a fillet, the others are more for a groove weld..
Reply:Originally Posted by MikeGyverNo penetration at the root? what process and material dimensions? have a normal pic of the weld?
Reply:Question for you pros, shouldn't it look more like one of these?Dave J. Attached ImagesDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-29 01:21 , Processed in 0.091167 second(s), 18 queries .
