Trying out #12 gas lens on WP-9 - not sure I have it right
发表于 2021-8-31 22:54:41 | 显示全部楼层 |阅读模式
Hey guys - I picked up this gas lens:http://www.arc-zone.com/index.php?ma...oducts_id=4888(45V64S - 3/32" (2.4mm) specifically)As well as this nozzle:http://www.arc-zone.com/index.php?ma...roducts_id=106(53N87 - # 12, 3/4" (19.1mm) specifically)and finally this collet:http://www.arc-zone.com/index.php?ma...products_id=69(13N23L - 3/32" (2.4mm) specifically)But I am realizing there's a gap behind the nozzle:IMG_0268.jpg by Jon Kensy, on FlickrAm I missing something?  I am getting semi weird gas coverageMiller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:You forgot the teflon insulator that replaces the small one. 54N63-20GAS LENSGASKETSee from this parts list.http://www.tectorch.com/detail/PDF/R...ts%20sheet.pdfWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonYou forgot the teflon insulator that replaces the small one. 54N63-20GAS LENSGASKETSee from this parts list.http://www.tectorch.com/detail/PDF/R...ts%20sheet.pdf
Reply:I find the chart from welding city to be very useful to newbs such as myself that also just got a wp9 as well with some large nozzle accessorieshttp://www.weldingcity.com/tig_parts_selection.JPG
Reply:Tig experts, what is the advantage of a "gas lens" over a standard ceramic cup? I am only running an older miller econotig, ang do well with a 3/32" or less tungsten and a 3/8 cup.  Most of my welding is under 1/8" fishing boat repairs, I have spool guns for the thicker stuff.
Reply:I'm sorry.  Is the entire cup on backwards?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255I'm sorry.  Is the entire cup on backwards?
GMT+8, 2025-12-29 01:12 , Processed in 0.112236 second(s), 18 queries .
