查看: 13|回复: 0
plasma-smazmaa
发表于 2021-8-31 22:54:33 | 显示全部楼层 |阅读模式
Well my chopper project is creeping along.I had to stop and make another tool today I took a bunch of pictures to show and tell so instead of i thousand words i probably cant spell heres a thousand pics  #1 the bike Attached Images
Reply:some parts off a drill press i scrapped Attached Images
Reply:3/4x3/4x16in bar Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Tapped and tigged Attached Images
Reply:Wow that Macro feature  makes this undercut[normally invisible to my naked eye] look like the Grand canyon  Attached Images
Reply:Ahh,thats better  Attached Images
Reply:One part done  Attached Images
Reply:Now you gotta make this part,mat list and instructions will be on last post if your still there  Attached Images
Reply:The middle peice is just spacing while welding Attached Images
Reply:part 2 complete! Attached Images
Reply:A peice of tube about 1in dia maybe 2in long 16gauge cut in half Attached Images
Reply:clean it up Attached Images
Reply:round the edges Attached Images
Reply:ready to weld Attached Images
Reply:Cut to size and ready to weld,anybody see the blunder im about to make  Attached Images
Reply:im takeing pics and still havent spotted it Attached Images
Reply:The sliding part is supposed to be  in the middle Attached Images
Reply:Im gonna take the smooth road,painful but smooth  Attached Images
Reply:Attached Images
Reply:weld,grind,cool,flip and repeat  Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Its a circle cutting attachment for my torch  I cut and pointed an old allen wrench and tacked it on the slider,sorry didnt get pic but you can see it here.I need it to make my axle plates and some gussets. Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:It would be nice if folks would  take a little more time to learn what your equipment can do before rushing on to the next greatest and latest toy on the market.I made this based on free plans at www.jerrysdiycorner.com this guy is amazing! He is my new fabricating idol  Oh, last pic bye the way and im all done typeing too,my finger is getting tired,later  Attached ImagesVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Nice tool build. Thanks for the pics.I wonder if a guide or roller at the tip end, would help with control?
Reply:You did gooder. Even plazma cutters need attachments for circles.
Reply:Very cool tool. I now have to make one for my plasma!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.Here is a circle cutter a friend of mine made (so he says).  He said I could have it so, I said OK.  It is basically the same concept, just used square stock.Thanks,JasonMillermatic 210 w/ SpoolgunMiller 375 ExtremeMiller Trailblazer 250GMiller AEAD 200-LEVictor Journeyman O/A
Reply:Jason that oughta work fine as long as you can lock the pointer in place.Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:I have a circle burners with wheel(s) one for inside the tip & another for outside the tip.  I don't like them myself  I can get better control by hand alone.Good job on the attachment.  The torch handle rest really stabilizes things. It makes the torch a bit harder to handle on a full circle but you get much better results.I made one similar several years ago.
Reply:Very nice work! I see that you have a Sportster engine for your project. While you are at it, why not rubber-mount that engine? It would be easy for a fellow like yourself and it makes riding a lot easier on the nerves.Regards.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:I had a different idea...
GMT+8, 2025-12-29 01:21 , Processed in 0.101009 second(s), 18 queries .
