AC Stick Welding Project: Plasma Cutting Flat Stock Decapitator of Doom
发表于 2021-8-31 22:54:25 | 显示全部楼层 |阅读模式
Morning, everyone! This is my newest project... I go through a LOT of 2" flat bar stock, 3/16 and 1/4 thick in the production of my YouTube videos, and I'm always looking for a better way to slice & dice it so its ready to use...I decided I'd make a combination dead-stop and straight edge for the plasma to speed things up, and so I did... I used nothing but scrap metal from around the shop, leftovers from other projects, and A/C on my Hobart Stick-Mate (which I resurrected for this build) just to make things that much more interesting. I completed this build with 6011 and 6013 only:And I'm pretty thrilled with how it came out. The guides are fully adjustable width-wise on a pair of rails, they're just clamped down so I can set this device to cut flat stock from 1" in width, to 10" wide.Also, the straight edge can be moved back and fourth, distance wise, so that I can cut strips between 1" and 8" long. Anyway, I really enjoyed this project... Hope you guys like the video [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:"If you burn your garage down, not my problem." That there is the best how to disclaimer EVER! Lmao!There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Haha glad you liked it [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:To check if something is square you measure across the diagonals.  Just measuring width, and/or length won't do it.  When diagonal measurements are equal you're square."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammTo check if something is square you measure across the diagonals.  Just measuring width, and/or length won't do it.  When diagonal measurements are equal you're square.
Reply:Ahh the crackle of 6011 on ac!  Most of my steel repair work is with 6011 on ac.  Enjoyed the video Lanse. Maybe for your next video project you could build a metal storage rack and do some spring cleaning.   I need to do that my self.Last edited by kald; 05-24-2013 at 06:30 PM.
Reply:Originally Posted by kaldMaybe for your next video project you could build a metal storage rack and do some spring cleaning.   I need to do that my self.
Reply:Originally Posted by copeThe boy is in need of some serious help with that shop!
Reply:Speaking from experience ($$$), that's the worst possible way to cut rectangular tubing on a dry saw. You'll kill a blade from putting too much downwards pressure since there are so many teeth in contact, they won't be able to dig in and instead scrape.. blades aren't cheap. They last several hundred to thousand good cuts, or one bad cut.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
GMT+8, 2025-12-29 07:03 , Processed in 0.078864 second(s), 18 queries .
