304 stainless drawing/print holder
发表于 2021-8-31 22:54:23 | 显示全部楼层 |阅读模式
Office guys need something to hold rolled up prints, so I got busy Also started a new plan table for An office guyUA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Fishinsin stationHow did you cut/drill the holes in the horizontal member?Opus
Reply:Automated axis plasma designed for pipeUA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
Reply:Thats SLICK!  I almost dont want to ask how much to get one of my own.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Wow that is sick, I likes me some stainless.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:What did you do to keep the large horizontal tube from bowing into a pretzel when you welded in all the vertical tubes that hold the prints?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:I just tacked the back side and hoped for the best, actually didn't pull as much as I though, I bounced around sides location a lot, and kept the heat down since I was grinding it smoothUA local 32Team weld-coolTeam miller elite tack upMiller pro-staff
GMT+8, 2025-12-29 03:29 , Processed in 0.100065 second(s), 18 queries .
