question please help
发表于 2021-8-31 22:54:23 | 显示全部楼层 |阅读模式
My dads tracker has a crack on the mower's wheel holder.i was wondering if i should take it off the tractor before i put some volts through it. would it mess up the battery or blow up? just a question i always wondered.this picture has an arrow to where id be welding, let me know if i should just remove it before i weld..thanks for readingNick Berg! Attached Images
Reply:Just remove the negative battery cable before welding and be sure to clamp your welding ground lead to the mower deck instead of the tractor itself.
Reply:Personally, I don't even bother to remove the cable. I have been welding off the back of my trucks for years with no  issues. I say weld away. Of course the battery is easy to get to, so if it makes you feel good, then pull the cable.
Reply:Originally Posted by walkerPersonally, I don't even bother to remove the cable. I have been welding off the back of my trucks for years with no  issues. I say weld away. Of course the battery is easy to get to, so if it makes you feel good, then pull the cable.
Reply:MY kubota deck cracked in the same spot, I just dropped the deck because all the grass underneath will catch fire. Raise the wheel up a notch or two it should not be in constant contact with the ground.
Reply:Good clean ground as close as possible, disconnect battery, garden hose nearby."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I don't know anything about big equipment, but I do know that welding with current flowing through small bearings can fry the bearings.BillLincoln v155-s with Tig Welder Ready Pack K2606-1One father's love of his autistic son www.inmyimage.com
Reply:I've welded on trucks and such and never disconnected the battery.  People forget that the battery acts like a giant capacitor anyway and you won't fry anything.  But.... If it makes you feel better, yeah, disconnect a terminal lead.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Go for it, good ground and water or fire extiguisher nearby...
GMT+8, 2025-12-29 03:30 , Processed in 0.071625 second(s), 18 queries .
