stainless steel heat difuser for a stack
发表于 2021-8-31 22:54:22 | 显示全部楼层 |阅读模式
here are a few pics of what i did this week. these are just the bottoms of the stack. stack hieght is around 18 feet. there are 4 of them. there for a new aluminum plant. Attached Images
Reply:Um, scratchin! where's the welds?I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:they are just tacked together at the moment. didnt get time to weld out yet weld pics will be coming next week
Reply:What type of set up are you using for that project?
Reply:Im assuming you mean welder wire and gas? The welder  is an old miller 300 the wire is 308lsi by avesta gas im using is a tri mix
Reply:fabproevanThe curve and surface of the 'rolled' conical sections look really smooth, how were they formed?If it was done with slip-rolls, what is your procedure toget the smooth curve with no maring or dimples.Opus
Reply:I do roll all the stainless with slip rolls. I must be just lucky not to get dimples in the steel the only prep i do is tape thin cardboard to the stainless before i roll. I haven't rolled anything thiner than 10g. I'll post pics of my rolls tomorrow.. but there are a few scratches in the stainless with i buff out with a scotchbrite padLast edited by fabproevan; 05-26-2013 at 12:20 AM.
Reply:here is a pic of my pinch rolls i use to roll all my stainless. and some ducting i just finished today Attached Images
GMT+8, 2025-12-29 03:29 , Processed in 0.098552 second(s), 18 queries .
